t-codes 171 and 174
Old 04-21-04, 05:48 PM
reyes45's Avatar
Question t-codes 171 and 174
On my 98 sierra, 4.3lt. my check engine went onand it registered codes 171, and 174. What could have coused these codes. Thank you.
Old 04-21-04, 07:17 PM
Both front O2 sensors are seeing a lean condition.
Possible causes:
Lean fuel condition caused by low fuel pressure, restricted fuel filter, clogged fuel injector(s), etc.
Vacuum leak in a hose or intake manifold gasket leak causing the O2 sensor to see a lean condition.
Those are some of the most common reasons.
Check (or get checked) the O2 sensors to make sure they are responding to fuel changes. Easy job for a technician that knows what he's doing.
Matt
Old 04-22-04, 05:27 PM
reyes45's Avatar
Smile
thanx matt,
I found that the pcv hose was leaking. I replaced it and erased the codes and they haven`t poped up yet. thanks for your advice.
reyes45
Old 04-22-04, 09:15 PM
Sounds like you got a good fix on it. Congrats.
