91 jeep sport clutch problem
Old 04-22-04, 12:48 AM
torr613
ok here goes i was driving home and out of no wear it felt like a pop at the clutch pedal i couldnt shift gears , then i used my left foot and pushed the clutch pedal up got it into 3 rd gear and costed home when i tryed to park couldnt get it into any gear pushed up on pedal and nothing happened .what happen and will this be pricey ?and can this be fixed at home ?
Old 04-22-04, 05:06 AM
carguyinva's Avatar
sounds like...
...either you blew something in the hydraulic system, if it has one...you'll have to look at it and have someone work the pedal and see what moves. or is it mechanical...levers, cables...that sort of thing. if it's mechanical, it may be very obvious unless something broke inside the bell housing. likewise, if you popped the master cyl or slave cylinder...there should be fluid showing. when looking for fluid from the master, don't forget to look inside where the push rod comes thru the fire wall for fluid running down under the carpet. it is also possible that something broke in the clutch itself so if you don't see something external, the trans will have to be removed to verify. i'd recommend replacing the clutch either way if the tranny has to be removed...and resurface the flywheel at the same time.
Old 04-22-04, 09:41 AM
torr613
do u have any idea how much this will cost ?
Old 04-22-04, 10:22 AM
carguyinva's Avatar
not unless...
...i knew exactly what broke in it...$100 for a blown slave cylinder installed...$600-800 for a broken clutch.
Old 04-22-04, 10:39 AM
torr613
1991 jeep sport
i just checked out my clutch it is hydralic ,i look into the clutch resorvior and the level does not change what does this mean if anything
Old 04-22-04, 10:56 AM
torr613
i looked at the resorvier and the level dont change when we apply the clutch .
also its hydralic
Old 04-22-04, 11:04 AM
carguyinva's Avatar
sounds like...
...a bad master cylinder then...
Old 04-22-04, 01:03 PM
Desi501's Avatar
If your losing clutch throw and the fluid is not disappearing, you have a bad Clutch master cylinder but I would recommend changing both if the slave is mounted externally.
In the future, please use the reply button to keep all this within the same thread. It's impossible to follow otherwise.
Old 04-22-04, 01:47 PM
torr613
how much does that run
Old 04-22-04, 01:49 PM
carguyinva's Avatar
have it checked...
...or call around. you don't have a definitive diagnosis yet anyways...just an opinion based on limited information
Old 04-22-04, 01:59 PM
torr613
how can i trouble shoot to narrow it down any sugestions
Old 04-22-04, 09:32 PM
torr613
just want to say thanks for ur help , it actually was the clutch pedal it snapped in half where the bracket is the bracket and the pedal split ,getting a new 1 in morning , hope i can locate 1 seems hard to find ,junk yard best bet u think ?
Old 04-23-04, 03:41 AM
Desi501's Avatar
Wow, that's unusual.
