99 alero bad mpg??
Old 04-22-04, 08:00 PM
W
99 alero bad mpg??
99 alero, my mpg is under 15 in town, it was not this bad before. I have had it checked out, air filter is fine. What can it be??? If it is just like this, how can I make it more gas economical with aftermarket parts??
2.4l 4door...........the engine too small for the car???
Old 04-22-04, 08:01 PM
W
also, only 42,000 miles on engine
Old 04-22-04, 08:58 PM
A couple of possibilities come to mind:
Bad fuel injector(s) - dripping fuel.
Bad fuel pressure regulator - ruptured diaphragm.
Bad O2 sensor - failed lean causing ECM to command rich.
MAP or MAF Sensor bad if so equipped.
Is the Check Engine Light on?
Any other symptoms besides the poor mileage?
Old 04-22-04, 09:04 PM
W
no check engine light on,oil change light because oil change place never resets it!!, the car seems sluggish thats about it. We had it hooked up to a machine a few months ago and they said no problems showed up on the computer.....???
Old 04-22-04, 09:13 PM
Sluggish could correlate to "rich" fuel condition.
Suggest looking for ruptured/leaky fuel pressure regulator diaphragm and/or drippy injectors.
It would be nice to know what the O2 sensor is doing and what the fuel trim stats look like if you can get someone to put a DSO on the O2 and scan the PCM for the fuel trim stats.
