04-26-04, 04:40 AM
bubbas1
Backup lights inop
This is for my sons 98 neon 5spd. Just about got all the little quirks worked out. His backup lights dont work. Checked both bulbs..they were fine. Checked fuse..was fine..replaced just in case it was faulty. The lights still dont work. I am thinking that there has to be a switch somewhere for when he puts it in reverse to activate the light. Can anyone tell me where it may be?? Taillights,turn signals,brake lights all work fine.
Thanks
Thanks
04-26-04, 09:07 AM
Look on the trans for a two wire switch, one wire will have power with the key on and the other goes to the lights. If you jump the two together the lights should lite. If they do the switch is bad.
