2000 Cavalier - odo/tripmeter light burnt
Old 04-26-04, 10:58 AM
blexann
I can't see the display on my odometer because the light burnt - can this bulb be replaced ?
thanks
Old 04-26-04, 11:23 AM
carguyinva's Avatar
it can...
...you'll need to remove the cluster tho
Old 04-26-04, 02:20 PM
blexann
is it worth the effort and is the job easy ?
Old 04-26-04, 02:40 PM
Plan on a couple of hours the top of the dash(the pad)needs to come off then the instument panel trim and then the cluster.You need to decide how bad you want to read your odometer,if it's the speedo you can't read I would certainly repair it.
