00 s-10 vibration
Old 04-26-04, 09:51 AM
tcooks
Vibration Too
I have a '96 Geo Prism and when I reach a high speed of say like 70 miles per hour, the steering wheel begins to shake. It becomes really noticeable when I begin to slow down from that speed. What can the problem be?
Old 04-27-04, 05:47 PM
PPakrs1
Sounds like you have a wheel "out of balance". Make sure all the tire pressures are correct and try rotating the front tires to the rear. If the problem goes away, you either lost a balance weight, or in my wife's case, you hit a pot hole and bent the rim...
If you still have a vibration at high speeds, your front end might need an alignment. I would check out these easy 2 things first, just my opinion, I'm not an expert...
Dean
Old 04-29-04, 02:43 PM
Desi501's Avatar
Your answer was "right on" except for this part. Alignment cannot cause a shimmy or vibration.
