1993 honda del sol over heating
Old 04-27-04, 01:08 AM
littlerob
Question 1993 honda del sol over heating
My daughters 1993 honda del sol over heating problem is driving me bonkers. I have had the t-stat replaced twice taken out the third time. Blow the upper radiator hose. I replaced hose with a new one, bled system.........over heating again. Is there a test I can do to rule out blow buy from the head gasket? I have taken this vehicle to the dealership and a master tech friend of mine has look at this vehicle. I might want to add there is 200000 miles on the vehicle.
Old 04-27-04, 02:30 PM
Call around and find a shop with a block tester that will tell you if you have combustion gases in the cooling system.An emission machine could also test the cooling system for HC's.If it's blowing white smoke or there is coolant in the oil it's a no brainer.
