Anti-freeze leaking
Old 05-02-04, 07:56 AM
D
Day Nam
Anti-freeze leaking
Subject: 1998 Dodge Caravan, 4-cylinder, 2.4L., 100,500 miles.
Yesterday, as my van was idling in the parking lot, a passer-by informed me that the anti-freeze was leaking from my van. Upon my inspection, a puddle of coolant was on the ground and the leak continued. The leak appears to be coming from the right side (near the serventine belts) but I could not see exactly where. The leak is definitely not coming from the radiator or the hose. When the A/C was turned off, the leak subsided. Since I was 2 hours away from home and on Saturday night, I decided to drive the car home without the A/C on. I monitored the temperature guage to make sure that the engine did not overheat during the trip. Got home OK.
This morning I wanted to take a closer look at the leak. I had the engine running with the A/C on for about 10-20 mins. I was able to duplicate the leak in the same area (could not see where; maybe near water pump?). At the same time, I noticed that the temperature gauge was pointing high. Shut off the engine immediately. The radiator fans seemed to be operating properly.
What type of problem am I dealing with????
Last edited by Day Nam; 05-02-04 at 07:38 PM. Reason: mileage information is added.
Old 05-02-04, 11:39 AM
Desi501's Avatar
Your describing the water pump area.
Old 05-02-04, 07:17 PM
N
Negoshe8n
You don't say how many miles are on your van. Neverless I would pull the water pump and replace it. Most auto stores offer lifetime warrantied water pumps.
Old 05-03-04, 02:32 PM
Desi501's Avatar
Don't fall for that hype. The parts are usually junk anyway and they don't cover the labor which is most of the job. Buy a name brand NEW water pump like a Carter.
Old 05-03-04, 08:03 PM
D
Day Nam
Thank you all. I had a reliable auto repair shop replace the water pump. At the same time, the timing belt was replaced. Problem solved.
