Toyota Camry has mild Vibration
Day Nam's Avatar
05-02-04, 07:26 PM   #1
Day Nam
I have a 1993 Toyota Camry (130,000 miles), 4 cylinder that seems to vibrate/shake mildly when speeding at or around 65 mph. At lower or higher speeds, the vibration is much less noticeable. The vibration appears to be more on the right side of the vehicle. Am I dealing with wheel balance problem??? I have not seen any major abnormal tire wear. If it is a wheel balance problem, should I do all 4 or only the right side wheels? Please advise.
toyotaman11769's Avatar
05-02-04, 09:20 PM   #2
I would start by balancing and checking all four tires for being true.
seancashmere's Avatar
NY
05-03-04, 08:07 AM   #3
Just a thought, but couldn't it also be a control arm being loose. I had a Mitsu Galant (95) with a similar problem and the right control arm was busted and needed to be replaced. Only, I got the same vibration at all speeds. I'm pretty sure that's not your problem, but after a wheel balance, if all isn't well, it's another place to take a peek.
poppalizerd's Avatar
05-09-04, 12:20 AM   #4
poppalizerd
sounds to me like you have a broken band in tire
you can sometimes see it if you take tire off let air all the way out there be a bubble or ripple in tire i think larry has the same ideal you need new tires they can look good but be bad
the_tow_guy's Avatar
FL
05-09-04, 06:34 AM   #5
Could be a bad CV also. Had that problem on my wife's '95 at about the same mileage. Was especially noticeable when accellerating hard. At 130k the cv's don't owe you anything. If they need replacing, do both sides and replace the axel assemblies.
