1992 chevy blazer
Old 05-08-04, 06:10 PM
1992 chevy blazer
hi guys i have a 1992 blazer the air comes out at the floor and defroster but not the vents at top
and does the freon go in the high side or low side
does it need R12 or the old
all help needed thanks guys
blackie
Old 05-09-04, 03:59 AM
You should see a black ball under the hood,the vacuum hose is more than likey not on it put back on and it should work.If it's a small blazer it should be on the drivers side inner fender.
Old 05-09-04, 04:48 AM
thanks i seen it
seen that black ball and a small black hose with a screw in it.. it's about the size of my little finger which is about the size of a pencil
thanks will ckeck it out
blackie
Old 05-09-04, 11:31 AM
thats not it
the hoses were on i guess it must be under the dash something wrong how do you get under do you have to take alot out
blackie
Old 05-09-04, 02:57 PM
By the distrib. there is a connection for vacumn (about 5 different vac lines come together). Check in that area for any disconnects or rotted lines, does the cruise work?
Trackbacks are On
Pingbacks are On
Refbacks are On
