95 Olds Ciera No Reverse Or Drive
Old 05-09-04, 08:28 PM
gtolvr
Exclamation 95 Olds Ciera No Reverse Or Drive
WHEN I PUT CAR INTO DRIVE OR REVERSE I GET NO CHANGE FROM THE TRANSMISSION. THERE IS A GRINDING NOISE COMING FROM WHAT SEEMS TO BE THE TORQUE CONVERTER OR SOMETHING ELSE INSIDE THE TRANSMISSION. OCCASIONALLY THERE IS A KNOCK FROM THE SAME LOCATION. POSSIBLY THE TORQUE CONVERTER OR TCC? FLUID LEVELS ARE GOOD AND TRANNY WAS SERVICED 12 MONTHS AGO.
THANKS FOR TIME!
GTOLVR[FONT=Courier New]
Old 05-10-04, 05:11 AM
carguyinva's Avatar
have you checked...
...the fluid level? noise and no drive/reverse sounds like it's either low on fluid or the pump has failed. in which case, you need another tranny or that one rebuilt. this doesn't appear to be a DIY job...unless you have a leak and can fix that.
