Flywheel help
racefan's Avatar
05-12-04, 03:14 PM   #1
Flywheel help
Can anyone tell me how many tooth flywheel is on a 1971 350ci 4 speed ElCamino? I want to try to find one @ a salvage yard & need to know how many tooth it is. Also is there a easy way to ID it & make sure without the obvious of counting them. Thanks, Mike
davo's Avatar
05-16-04, 06:57 AM   #2
Take the old 1 with you that is the best bet ,make sure you have it surfaced before installation.Good luck finding 1 that is kinda old for even junkyards.You may be ahead to buy a new aftermarket flywheel.If the old flywheel is chewed up make sure you shim the NEW starter to match the new flywheel.
