2001 sable/taurus trunk leak
Old 05-13-04, 09:31 AM
rob
rob is offline
Hi - Anybody know of problems with the 2001 sable/taurus water leaks that fill up the trunk with water. I'm guessing that this is a common problem.
This car is like new and I don't see any broken seals or poorly fitting joints. During the rains though, the spare tire area in the trunk fills with water. I am contemplating getting in the trunk and having water splashed on it, but I'm not really looking forward to that!
Thanks
Old 05-13-04, 10:01 AM
carguyinva's Avatar
that's...
...the quickest way. be sure to take a flashlight in with you and have someone you trust on the outside...*LOL*
Old 05-13-04, 03:04 PM
Start low with the hose and slowly work your way up to the roof.Don't use a spray nozzle on the hose remove it and just trickle the water on.A nozzle can force a leak that doesn't really exist.If the water is dirty it's coming up from the road if clear it's from the rain hitting the car.
Old 05-14-04, 03:24 PM
Bugalou
It could also come in because of a bad seal around the rear window..after a rain, see if its wet inside the car by the window sill..
Bug
