1995 Villager Hard To Start, Blows 5 Ams Fuse
Old 05-25-04, 10:54 AM
islandermike
My 1995 Mercury Villager with 120k miles is blowing the 5 amps Engine Control fuse and hard to start. I know that the fuse has something to do with it, being hard to start, because this was blown once and the effect was exactly the same. The only difference now is that it keeps blowing the 5 amp Engine Contrl Fuse.
Thanks
Old 05-25-04, 04:06 PM
You will need a wiring diagram to trace that circuit.You may want to try the local library for one.I do not have one maybe someone else who comes here may have it.If you can't find a short in the wiring the pcm may be bad blowing the fuse.
Old 05-25-04, 05:54 PM
billys68ss's Avatar
That fuse provides power to the PCM and the DRL (Daytime Running Lamp) module. I would disconnect the module to rule that out. You may have a wire that has rubbed through.
Hope this is helpful to ya,
Billy
Old 05-25-04, 06:01 PM
islandermike
You are exactly correct. It was the daytime running light that has pinched wired. Thank you very much for your help.
