a/c clutch won't engage
Old 05-30-04, 03:30 PM
stumped04
Clutch on the a/c compressor not engaging. Fuse is good. What is the wiring at the clutch and what voltages should I be reading? Thanks in advance.
1984 Pontiac Parisienne-305 Chevy engine
Old 05-30-04, 05:35 PM
Desi501's Avatar
There are many things that will prevent an A/C clutch from energizing. Low freon is the most common. You need to put a set of gauges on it to start with to determine if you even have enough freon to kick the system on. After that you'll need a schematic to determine the wiring configuration for that vehicle since they all differ. Switches or relays are common problems also.
Old 05-31-04, 10:23 AM
stumped04
Thanks Desi. Didnt even think about low freon. Bought the car 3 mos ago and havent even checked it. Ill let you know how it goes.
