Parking brake adjustment
On a 1999 Chev. Silverado 1/2 ton, RWD, is there an adjustment for the parking brake shoes at the wheel, or is the cable length theonly adjustment.
Thanks for any help.
Doug
Doug
Moved
I am not real sure about that truck, so I moved the thered here so some of the Pro Mods here can have a shot at it. I hope they can help you.
Yes, I believe there is if it has rear disc brakes. You'll have to remove the caliper and rotor. Completely back off the cable adjustment before adjusting the shoe, then re-adjust the cable once rotors are back on. If they are drum brakes, do the same thing with the brake adjustment.
Previous Thread
Next Thread
