here my question and answers... (3 questions )
Old 06-04-04, 05:36 PM
Tresco
hey i have three questions here...i have the anwsers as well..im just not sure im right or wrong ..so could someone please tell me if im right or wrong..thanks
DISC BRAKE CHALLENGE
Customer Complaint: When i backed out of the driveway this morning, I had no brakes.I pushed the brake pedal and it went almost to the floor
Customer Vehicleodge Dakota
possible caues i have are
1. Air in the hydrualic system
2. Brake Wires could be cut
3. blown out wheel cylinder
4. a leak in the master cylinder
5. Brake cylinder seal/lining problem
DRUM BRAKE CHALLENGE
Customer Complaint: The right rear wheel of my car seems to be dragging.It is very hot,smells,and is smoking
Customer Vehicle: Plymouth Horizon
possible causes i have are
1. Broken or weak return springs
2. froozn piston
3. obstructed master cylinder bypass port
4. swollen rubber parts due to improper brake fluid
Customer Complaint: When i pull up to a stoplight, the brakes make a grinding sound.It Sounds like metal against metal.
Customer Vehicle: Ford Mustang
the possible causes i have are
1. Loose or worn caliper
2. missing anti-rattle springs
3. Brake shoes are wron
4. Brake pads are worn
5. The brake drum keeps alot of brake dust inside the brake assembly
thanks again
Old 06-04-04, 08:46 PM
well I would suspect a bad master cylinder on the dakota assuming there wasnt any leaks other than the master cylinder which may or may not so any signs of leaking or previous work done to the brake system that would allow air to be in the system.
on the horizon 1 and 4 would be possible but would also suspect frozen emergency brake cable, or leaking wheel cylinder.
I would assume the same on the mustang.
Old 06-05-04, 02:01 PM
Tresco
thanks alot..
Tresco
Old 06-05-04, 02:14 PM
If the Dakota has abs the bpmv may be bad.The Horizon could have a bad rr brake hose.The Mustang may have budget pads and shoes installed.These are just to add to Bejay's list.
Old 06-05-04, 03:40 PM
Desi501's Avatar
Well, on the Dakota
Air in the hydraulic system is possible but something else caused it. You have to find that.
By "brake wire" I assume you mean electrical-forget that
#3 and #5 seem to be the same thing
The basic fact is you either have a leak or a bad master cylinder
On the Horizon- all your choices are possible
On the Mustang
#1 is only possible if the caliper is contacting the rotor because it fell off.
#2 , #3 and #5. are NO
#4 is the most likely
Trackbacks are On
Pingbacks are On
Refbacks are On
