Ac Drainage
Old 06-08-04, 02:30 PM
RICOZALES
Ac Drainage
I've Got A Slight Problem,with The Ac Condensation In Or Under My Carpet
Old 06-08-04, 03:01 PM
89blaze's Avatar
The drain for the evaporator under your dash is clogged or has come loose. there will be a small rubber or plastic tube from the bottom of the air box under the dash (above the leak). this will need to be cleaned out or replaced.
