aroura air conditioner
Old 06-13-04, 07:39 AM
Does anyone know where the low side service port is on a 98 olds. aroura? It has a low and high side fittting but their both on the high side line.
Thank you
Jay
Old 06-13-04, 08:29 AM
Desi501's Avatar
Jay
No they're not. One of them is after the oriface tube making it low side access.
Old 06-13-04, 09:04 AM
Thanks for the response Desi! We did put freon in that port but still cannot get the compresser to go on. It is a new compresser and we are getting juice at the clutch just for a second when the car is started. Perhaps there is not enough pressure in the system?
Jay
Old 06-13-04, 10:57 AM
Desi501's Avatar
Does it have ATC? If so, you may have to disconnect the battery to clear the codes that shut it down.
Old 06-13-04, 12:00 PM
Thanks again Desi. We did disconnect the battery for about 3 minutes. Maybe we should have done it for a longer period although it was enough time to mess up the code on the radio. Maybe we'll try doing it longer.
Thanks again, Jay
Old 06-13-04, 12:16 PM
billys68ss's Avatar
Do you know that you have enough freon in the system to get the compressor started? What was the malfunction prior to replacing the compressor? Did you pull vacuum on the system before you tried to shoot in freon?
Hope this helps,
Billy
Old 06-13-04, 02:42 PM
Desi501's Avatar
Thanks again, Jay
That should have been long enough.
Old 06-13-04, 06:13 PM
Just dropping a line that I appreciate all the help and we are still working on it. We noticed that when we first start the car with the air on the compresser spins for a second and then stops leading me to think that maybe theres not enough pressure in the system. We only put one 12 oz. can in but when trying to add another it didn't want to take it. I think that may be the next move to try another can.
Thanks again,
Jay
Old 06-13-04, 07:12 PM
Desi501's Avatar
That may be possible but don't just blindly add refrigerant to the system. You need to put a set of gauges on the to see what the pressures are first. If it's low on refrigerant, it should be continuously starting and stopping, not just once.
