pitman arm
Old 06-20-04, 03:13 PM
roxicod
pitman arm
Im trying to change the pitman arm on my 92 dodge dakota p.u.I have both bolts off but it wont come off.Ive been using pitman arm puller but it wont budge.
Old 06-20-04, 04:32 PM
Desi501's Avatar
Your going to need a real high grade puller because they're really on there. Try smacking the puller bolt right on the end with a good size hammer when you have full pressure on it.
Old 06-24-04, 10:18 PM
joeyc220
use a mallet and a arm puller.. its a pain in the ass i did it on a cherokee.. u can also try a breaker bar
Old 06-25-04, 02:40 AM
Desi501's Avatar
The mallet won't be any help if it's made of anything but steel. It's the sharp impact of the hammer that will help break it loose once the puller has enough tension. You really need to use an impact gun to get that puller tight enough. This isn't a job for for old carpenter's tools.
