Water in the oil
Old 06-21-04, 08:19 AM
K
Water in the oil
I've got a 1994 4-cyl, chev engine which I carelessly let freeze last winter. Now water in the oil. My mechanic ran a block sealer through it and it has improved but there is still some water where it should not be -
As you may have guessed, I'm trying to get by without replacing the engine. Would another block sealer treatment help? Any other ideas?
This engine is in a boat so replacement is VERY expensive.
Old 06-21-04, 10:09 AM
the_tow_guy's Avatar
Received 258 Upvotes on 209 Posts
It's a band-aid at best; basically rearranging the deck chairs on the Titanic. Probably a worse gamble on a boat than in a car since you could be in a bad situation with no propulsion available if it lets go.
Old 06-21-04, 01:48 PM
Desi501's Avatar
The only thing in your favor is that you don't have a radiator for the sealer to destroy. A crack will expand and contract with temperature and the sealer is just snake oil. I've said it before "There is no such thing as mechanic in a can". Those product make someone rich but fix very little. Bite the bullet and buy a new block.
