Clutch Problem
Clutch Problem
1998 Hyndai Triboun 4Cyl DOHC. Manual Transaxle.
I have a problem with my clutch not engaging when I push it down it is hard as a rock. I also heard a clattering nosie before this happend. All gears in the transaxle shift smoothly.
Received 0 Votes
The transaxle will have to be removed to find out what broke but a clutch fork comes to mind as a possibility.Clattering noises are not a good sign.Remove the trans and let us know what you find.
Received 0 Votes
sounds to me if it;s making a noise it might be the throw out baron.if i replaced it or clutch,it'd go ahead and spend a little bit more bucks and buy a complete clutch kit which consists of everything you'll need.
