jthompson Z-Head Question
Old 06-23-04, 09:23 PM
Sent you a few PMs to no avail
Restoring an '86 GT w/MT & 5.0
Should have A, B, or C heads according to literature
I have "Z" heads
Have you run across this before?
I know A, B, C, are junk but, @ a couple of $K I don't want to replace these if I can have a machine shop fixem
Thanks man...
Old 09-07-04, 09:53 PM
Just tryin to bump this up 'cause I see you are back
Old 09-08-04, 04:14 PM
took care of this with pm's....I didnt' have my preferences set right and wasn't getting pm emails
for anyone interested, ALL mustang 1986 5.0 engines recieved fords grace with a set of the infamous "e6te" heads. (the non-ho roller 5.0 lincoln/crown vic motors recieved these lousy heads for years after) they were a swirl head designed for improved emissions. Port em and work em anyway you want, they still won't be as good as the 87-93 e7 heads, which are still restrictive but will free up 25 horses from changing heads. If doing the swap, just measure valve to cylinder clearance, as the 86 pistons, unlike the 87+ arent cut for valve reliefs, however the e7's should still fit on an 86 block. Take care all!
Old 09-08-04, 09:42 PM
Thanks
Thanks jt
BTW, I thought I had a ringer
Must be my driving skills...yeeehaaawww!
And thanks for the tip on Four Eyed Pride!
Lordy Mama...I'm-a-comin' home
---slick
Old 09-08-04, 10:34 PM
it'll be cool to see you there, I got addicted long ago
