Turn signals
Old 06-27-04, 07:00 AM
Anitaride's Avatar
Turn signals
'96 Linc. Town Car. Signals and 4way flashers do not work. Fuses look ok.
Old 06-27-04, 11:02 AM
D
Test the fuses with a meter then if they check ok try replacing the t/s relay common name is the flasher.Are the bulbs ok?If the checks come out ok maybe the t/s switch is faulty.A wiring diagram would help but I don't have one sorry.
Old 06-27-04, 09:09 PM
cheapfurcoat
Ford vehicles with cornering lamps (such as your Lincoln) have a special "electronic" flasher unit. It is not likely found at Wal-Mart or even auto parts stores. It must be obtained from a Ford-Lincoln-Mercury dealer's parts dept. Do not try to substitute with a standard flasher unit as it does not work.
My Taurus SHO has cornering lamps and has gone through two of those jobbys so far over the 10 years I have owned it.
