A/C drainage leaking onto floor carpet
QBMagic's Avatar
06-27-04, 06:10 AM   #1
QBMagic
Suddenly the passenger side carpet in my 1998 Olds Intrigue is soaked from the A/C. Is this fairly easily fixed by a non mechnical person? Thanks
davo's Avatar
06-27-04, 09:17 AM   #2
You need to clean the drain on the outside of the firewall to prevent the problem.It will be on the passenger side of the car obviously with a rubber elbow usually.You can remove it and probe in the hole an inch with a wire but no further or you will damage the evaporator.If water pours out when you remove the elbow clean the elbow and reinstall.
Johnc280's Avatar
07-09-04, 06:41 PM   #3
Johnc280
Davo is right about the cause of the water. If you cannot un-clog it with a piece of wire then try to find a friend with an air compressor so blow air up the drain tube. If not then try a couple of repair shops. I do this about twice a month for people and dont charge them anything.
Good luck,
Johnny
ASE Tech and Owner
