Equipment mount
Old 06-30-04, 02:57 PM
bobmattypa
Equipment mount
Have a 90 chevy van, with a 4.3 engine. The mounting bracked keeps breaking at power steering pump. is there a answer to this problem. Do not want to sell. ha ha
Old 06-30-04, 03:13 PM
D
Is the small steel bracket at the rear of the pump still there and installed properly?If it is make sure nothing is causing the bracket to twist,pulley alignment,debris on the mounting area of the block or unequal tightening of the bracket during installation.If a/c equipped is the compessor in good condition?
Old 07-02-04, 05:57 PM
bobmattypa
streering brace
I have change motor 15mos. ago. Installed new braces. The motor was outside truck for installion.I have welded a angle brace from pump brace to brace on block."the block it self". I think chevy sould do the same!!!! thank you ps if it holds i will do the same too new brace
