1993 toyota corolla ignition problems
Old 07-01-04, 09:23 PM
kris74
i have replaced the rotor button, distributor cap, and coil, but still can not get any fire to the plugs. the connections all appear to be ok, can someone please help with suggestions.
Old 07-01-04, 11:33 PM
B
does the rotor turn when you crank the engine over?
if not may be a timing belt problem
possible bad igniter causing it not to fire.
maybe someone else will post more suggestions but you may want to post the engine size.
Old 07-02-04, 04:30 AM
the_tow_guy's Avatar
Received 53 Votes on 43 Posts
Coil wire and/or plug wires?
Old 07-02-04, 05:17 AM
Check this
A easy check is remove the cap were you put the oil in you should be able to see a camshaft.Have a friend turn over engine,Does it move?If not your timing belt is toast.The good part is if it is toast Toyota engines are not self destucting like Honda.also if you do find the belt bad replace water pump at same time.
Toyotaman might have some other possible causes.
Old 07-02-04, 07:28 PM
marquiess
Lightbulb
Does the starter turn but not the engine making it look like no spark.
I came across that quite often when I was a breakdown mechanic in England.
