97 Chevy Tahoe...Computer or sensor problem?
Old 07-02-04, 09:46 PM
GM68
My problem is after a run on the highway in which everthing runs fine I will restart vehicle take off and the speedo does not work followed by the abs lite coming on at about"guessing" 5 miles an hour and the transmission is not shifting out of first unless you put it into 2 then your stuck in second if you drive long enough the service engine soon lite will come on then after 2 or 3 stops and some rest the speedo works and it shifts fine.
Sounds like a vehicle speed sensor or computer problems? all thoughts welcome.
Old 07-03-04, 03:53 AM
Desi501's Avatar
My thoughts would be, let's find out. Have the codes read and post them here. We may be able to help then. You could be right about the speed sensor.
Old 07-03-04, 12:19 PM
GM68
The dtcs code left behind was 24......
Old 07-03-04, 02:02 PM
Desi501's Avatar
I assume this is an ABS code because it's not an OBDII code.
An ABS problem can have no effect on you transmission or speedometer
Did you also scan the PCM for codes?
Trackbacks are On
Pingbacks are On
Refbacks are On
