99 Taurus Won't Start
Old 07-03-04, 10:26 AM
98strat
My car just decided not to start one day. It has been running perfect. I went to leave for work one morning and it turns over perfect but will not start. It acts like it won'ts to start but won't. I changed the plugs and fuel filter and it still won't start. The car is getting fire to the plugs and the fuel pump is pumping fuel. What else can I ckeck? Thanks. Steve.
Old 07-05-04, 05:40 AM
You need to check fuel pressure with a guage,check for injector pulse with a noid light and check spark with a spark tester not a screwdriver.Then post your findings.
Old 07-15-04, 01:49 PM
MRSWANT2KNOW
Smile Try This
There's A Gray Plug On The Passenger Side Under Ur Hood...take N Replace It...a Dealership Product...that's What Started My Car...also If U Had A Flat...n The Trunk On The Passenger Side There Is A Switch...if It Is Up Push It Down N Ur Car Will Start...
