1997 dodge ram warning lights in instr. panel
Old 07-04-04, 09:24 PM
R
97 ram 81000 mi 318 2wd auto, all the warning lights came on, vehicle ran ok. after stopping and starting back they were ok. a few weeks later two of them came on, ok after restart. ???
any sugesstions, would unhookig battery reset?
Old 07-05-04, 05:02 AM
D
Sounds like you have a loose power or ground connection somewhere or the ip cluster is going bad or a body control module problem.I doubt unhooking the battery will help any but it's free so try it maybe the connections at the battery are loose or corroded causing the problem.
