Toyota Power Window Problem
Old 07-06-04, 07:41 AM
T
tmart68
My power window won't go up or down, and there's this crackling and popping sound when I've tried to do anything about it. Obviously the motor is toast; however, I would like any info on what cost is involved and whether I should stick with the dealer (way too high on labor) or if an independent foreign auto repair would be a better choice. (I'm a single woman, so I think repair shops see $$$ when they see me coming. Just want to be armed for battle!) Car is 93 Camry. Thanks in advance!
Old 07-06-04, 10:59 AM
G
Received 2 Votes on 2 Posts
Toyotaman will have the answer. I have seen some cars which use a thick plastic tape with teeth on one side to run the power windows. The noise you describe sounds like some teeth have broken off. If this is the case, a new tape is not too difficult to install and a fraction of the cost of a new motor and tape assembly. It may be best to have a shop do it because you could get your hand trapped if the window drops and / get it out of alignment, but an informed shopper beats one who has no idea of the problem.
