Engine just died on me I need help
Closed Thread
Old 07-09-04, 02:50 AM
B
Blindboy
Question Engine just died on me I need help
I have a Renault Clio 1.4 RT L (93), I have been using the car all day, then on way home every thing just stopped, the unsual bit was it was quiet no spluttering or warning just cut out without warning.
I have told it is probably electrical and it had been raining heavly all day, but it been 2 days now and still it won't start. When you go to start it it sounds like it is just about to turn over, but then nothing. Can anyone offer any advise as to the possible cause?
Cheers Blinboy
Old 07-09-04, 03:50 AM
Desi501's Avatar
Well, there's your problem!
LOL just teasing.
You have to approach this like any other "no start" condition. You have to check for 4 things that you need to run
1) compression
2) good spark at the plug
3) correct fuel pressure
4) injecter pulse
Old 07-09-04, 05:11 AM
B
Blindboy
Thanks
I have gone through these, as you suggested, checks and all seems ok, before i start any more work i.e removing major parts like the alternator and checking that i was wondering if their was any other sources as to why this could happen.
Closed Thread
