No go Fox
Old 07-09-04, 06:32 AM
ade64
No go Fox
1988 VW Fox w/ carb will not start, turns over, fuel smell inside car, mileage approx 200,000 miles, starting problems since 3 weeks, has run until now, new plugs & wires, plus are wet. dist. suspect, oil at base where it goes into block.
Old 07-09-04, 05:37 PM
Crank/no start, wet plugs, fuel smell, no fire..............
You need to get a spark tester and see if you're getting a good spark at the plugs and go from there.
You also need to check your timing belt if equipped and make sure it's not broken.
Matt
Old 07-13-04, 12:55 PM
ade64
pop cap on distributor it turns so is it safe to say timing belt is not broken?
is grounding plug against metal surface not a good way to test for spark?
