Tapping Noise
Old 07-12-04, 06:14 AM
Rc4b
Tapping Noise
I have a 1995 Chryler Cirrus 6cyl which I set the timing on it and put everything back and went to road test it! But As I road test it and got back home.I looked under the hood and notice that there was a tapping noise under the front valve cover!!
My question is could this be from setting the timing and the timing not be right or could it be something else?
I did notice that, that spark plug wire is a little burned! time to change the wires.
Appreciate any advice you could give!!
Thank you in advance!!!!!!!
Ruben
Old 07-12-04, 09:20 AM
pt_fixer's Avatar
A bad plug wire that allows for arcing will sound like a tap. Try replacing the wires first and then go from there. I doubt that you created a valve tap from just adjusting the timing.
Old 07-12-04, 02:28 PM
Desi501's Avatar
Check the oil level and when it was changed last.
