Enhanced Tracking System (ETS) for '97 Pontiac Grand AM
chiefbrass's Avatar
07-12-04, 06:20 PM   #1
chiefbrass
I need some information about the ETS on a 1997 Pontiac Grand AM SE, 4 cyl. "ETS off" is constantly lit on the dash. One day for a few minutes, it went off, but came back on again. I think it's somehow tied into a sensor for wheel hug/bearing assembly. Can anyone help.
Thanks in advance,
davo's Avatar
07-13-04, 04:34 AM   #2
If you have a bad speed sensor(wheel bearing assembly)it will cause that so will a bad wire to a sensor.If you have an engine misfire you can get the same problem.Someone with a scantool will have to read the codes for you.Abs and powertrain codes need to be read and Autozone can only do 96 and up powertrain codes.Get the codes and we will try to help.
chiefbrass's Avatar
07-13-04, 06:55 AM   #3
chiefbrass
Thanks!
Thanks for the speedy reply. I'll see if I can get some codes and get back to you.
