1998 Plymouth Neon Backup Lights
Old 07-15-04, 01:21 PM
L
I am at a sticking point in trying to figure out what happen to my backup lights. They quit working about a month ago. First thing I did was replaced the bulbs, didn't help. I then replaced the switch on the transaxle, didn't help. I can't see any other obvious problems but I also don't want to spend 60+ dollars an hour for a mechanic to hunt down the problem either. Any suggestions as to what I might have overlooked?
Leslie
Old 07-15-04, 02:04 PM
D
Check all of your fuses.After you confirm they are ok remove the wire from the reverse switch and jump across it,check the lights if they are on you have a bad new switch or something is wrong in the tranaxle.If they don't light you need to start looking for a broken wire or bad ground somewhere.
Old 07-16-04, 07:42 PM
N
Talking back ups
If worse comes to worst, you can always wire the lights to a toggle switch. Then you can turn them on ,and off as needed. It works great for tailgaters.
