Geo engine in an airplane
Old 07-16-04, 07:14 PM
flygeo
Question Geo engine in an airplane
I'm currently building a homebuilt bi-plane in my garage with a Geo 1.3 liter hanging on the front. It should work out really well with the fuel injector.
Ever since I moved the working engine from the test stand to the airframe I can't get the silly thing to start. It will crank over, but not start.
The engine gets spark but the fuel injectors won't open. A check of the injectors (with a noid light) show that they all open momentarily (once) when I begin to crank the engine but then remain closed.
I've replaced the ignitor and the ECM (ouch!). I traced all the wiring and it appears to be wired correctly.
Any ideas out here?
Old 07-17-04, 04:34 AM
what year model is this engine?
double check to make sure all grounds are hooked up.
Old 07-17-04, 01:52 PM
flygeo
It is a 2000 Geo 1.3, using a 1995 Tracker 1.6 liter (vin 6) computer and distributor.
I've triple checked the grounds.
Trackbacks are On
Pingbacks are On
Refbacks are On
