Fog from AC vents
Old 07-18-04, 02:40 PM
tnash
Fog from AC vents
I have a 1988 Toyota Landcruiser, with auto transmission.
When I run the AC it works well for a while (15-20 minutes) and then stops cooling and emits a white fog from the vents. I can turn off the AC for a while, usually more than an hour, which normally includes turning off the engine, and the AC will work again for a short period when I turn it on.
There are not any signs of fluid on the passenger side floor. I have never serviced the heater core. I also have a musty smell (typical I think) from the AC system when I restart the AC system after it has sat idle for several hours.
Any help is appreciated.
Old 07-18-04, 05:08 PM
Desi501's Avatar
Your evaporator could be freezing up. Does the blower force seem to decline at the same time? You should have the A/C thermostat checked
Old 07-18-04, 10:26 PM
tnash
Thanks for the reply. I have not noticed any reduction in blower force. I usually shut the AC down pretty quick when this happens. I will verify.
What about the heater core being the issue? Any thought on if this might be the cause?
Old 07-19-04, 04:05 PM
Desi501's Avatar
Not if you don't have the heat on. There is a blend door separating the core from the air your getting. You would also be getting a sweet smell and an oily residue on the windsheild.
Trackbacks are On
Pingbacks are On
Refbacks are On
