washer pump
Old 07-25-04, 02:30 PM
washer pump
I was wondering how I would change the washer pump on a 3.1 92 Cavalier?
Thanks
Old 07-26-04, 10:58 AM
the_tow_guy's Avatar
Not sure about a Cavalier specifically, but all you should need to do is trace the water line from the tank to find the pump. It'll be about the size of a golf ball or smaller and may be mounted either right to the side or bottom of the washer tank or possibly on a fender well. Should have a two wire connector that will pull off and the pump itself will either just pull off or may have 1 or 2 screws holding it down.
