Tape Deck problem
Feloxi's Avatar
07-26-04, 03:45 PM   #1
Feloxi
Tape Deck problem
Hi,
I have a 1993 Oldsmobile Cutlass Supreme LS.
My problem is the tape deck. It switches between forward and reverse playing constantly. For example, I'll insert a tape and it will play for about 5 seconds, then it will reverse and play the other side for 5 seconds, then reverse again and play the other side, and it continues. The radio works fine, it's just the tape deck. I just cleaned it with Isopropyl Alcohol, it didn't help.
If anybody knows anything about fixing this, or you need more information, please help.
jeff67's Avatar
NC
07-26-04, 09:41 PM   #2
I don't know what's wrong with it, but you're probably best off replacing it with it a new one or you might find the same unit at a junk yard. 1st, you could try taking it apart and see if anything is stuck in there preventing the take up reel from turning and see if a belt got off track.
You should also post your problem in the Electric: Home Entertainment forum where you can get additional advice, even though its not home entertainment.
tvshooter's Avatar
ME
07-27-04, 06:23 AM   #3
I've seen several decks do this- they just get old and the motors weaken and have trouble turning the tape, and therefore they "think" it's the end of the tape and they flip over. If this is the original tape deck in the car, or even if it's about as old as the original, you're better off just replacing it.
Feloxi's Avatar
07-27-04, 03:31 PM   #4
Feloxi
Well hey thanks, i fiddled with it, there's nothing wrong with it, i guess it's just old. A new question, if anybody checks this,
the new tape decks on the market with CD players, are they compatible with my car? Or do i have to get an old one in order for anythign to work.
davo's Avatar
07-27-04, 04:00 PM   #5
Newer ones that are aftermarket will work but you will need to wire it in the existing wires won't just plug in.
