Air Conditioner switch
Old 07-26-04, 07:36 PM
I took the compressor, hoses and accumulater off my sons wrecked 93 bonneville 3800 and put it on my 92 Olds 88 (same motor). And I would like to know how to get the compressor to engage so I can charge the system. Thanks
Old 07-27-04, 04:34 AM
the_tow_guy's Avatar
Do you have a vacuum pump to evacuate the system and test equipment to do a leak check? Frankly, since you've done all the expensive work, I would take it to an ac specialty shop to get it recharged. Among other things they can do a leak check after getting it charged.
If you didn't buy a new receiver/drier and install it - stop! Do that before you go any further.
Old 07-27-04, 01:54 PM
The switch to jumper is on the accumulator but I would make sure I pulled a vacuum and possibly add about 2 ounces of oil to the system.Replacing the accumulator would be a good idea also as would the orifice tube.
