Escort Warning buzzer
Old 07-27-04, 09:11 AM
arnoldom
I have a 94 Escort. When i open the door, the warning buzzer keeps buzzing even after I've turned off the lights and taken out the key from the ignition switch. My brake light has also come one even though I've checked the brakes and fluid and everything seems fine. These two items seem to have come on at about the same time . ANy ideas?
Old 07-29-04, 04:26 PM
The buzzer itself is most likely bad,unplug it and see what happens.You may also have a short some where.
Old 07-29-04, 04:55 PM
Have you checked to make sure the parking brake is completely released? If it is the slightest bit engaged, the light will be on.
