94 Cougar - slipping automatic transmission
I have a 4.6L with 42K miles. Yesterday morning I drove 65 miles to an nearby town and came back mid afternoon. About 20 miles from home the transmission slipped and the tach reved up a couple K rpm, then in a second or so it reingaged. This happened between 65-70 mph and occurred four times. I dropped down to 55-60 mph and made it back home without any more "events." The fluid is pink, but slightly too full (I checked it in park w/ engine idling on level ground). Is that the problem, too much fluid? Is it just the heat (over 90 yesterday afternoon)? Should I put in new fluid and filter? Maybe something internal?
Thanks for any input or ideas.
Overfilled fluid can cause problems depends on how overfull.At this point you have nothing to lose by changing the fluid and filter except a couple bucks.It may not hurt to see if any trans codes are stored in the computer but I'm not sure if Ford used a fully electronic trans in your car so ask the tranny shop you get to read the codes before you bother driving there.If there is an electrical problem a code may help diagnose the problem.
