96 Grand Am
Old 07-28-04, 04:40 PM
P
par58
Question 96 Grand Am
I just bought my DD(Darling Daughter) her first car, it is a 1996 Grand AM SE 4 cyl. Automatic trans. Looks great and seems to run really well. The problem is when the fuel gage goes below 1/4 tank the car wont start. I can get some gas and put it in the tank and it cranks up just fine. What could be the cause of this.
Thanks Pat :
PS How do you get the drivers side door panel off? sorry for the other question but i just needed to know. :
Old 07-29-04, 04:06 PM
P
par58
Cool
Thanks Pat :
Sombody at least view the post
Old 07-29-04, 04:19 PM
D
Well for starters the gas guage is off not reading properly and since it has been run dry numerous times replace the pump,filter sock and fuel filter at the same time.On the door there are screws to remove hidden behind covers(look and you will find them) after that the panel basically pulls off with the help of a door panel tool.What kind of door problem you having?
Old 07-29-04, 04:31 PM
There could be something wrong with the fuel level sending unit or the float.
Old 07-29-04, 04:56 PM
P
par58
If the float was messed up wouldnt the gauge be wrong but the car still run?
Old 07-29-04, 05:00 PM
P
par58
Its just not on secure, i think some clips need to be replaced.
Old 07-29-04, 06:55 PM
It might be sending the signal to the gauge that there is 1/4 tank of gas left when there is actually no gas in the tank or when the gauge reads 1/2 tank, there is actually 1/4 tank.
When you get to 1/4 tank level on the gauge fill the tank up with gas and take note of how many gallons you had to pump to fill it up. If it is close to the fuel tank capacity, as stated in the owners manual, then you know you have a problem somewhere with the fuel level sending unit/float to gas gauge circuit.
Also, add some fuel injector cleaner to the gas (if you have fuel injection).
Old 07-29-04, 07:00 PM
P
par58
Thanks I will try that
Old 07-30-04, 03:04 PM
D
I'm sorry I meant replace the fuel pump while you are replacing the fuel level sender.If it's been run bone dry several times it's life span is going to be short.It's up to you if you want to drop the gas tank twice.If the door is loose you need to remove it to replace the clips.
