93 Nissan Altima Power Window
coburn's Avatar
07-28-04, 04:43 PM   #1
coburn
Right rear power window does not work. When the motor was taken out and 12 volts applied, the mechanism still moves up and down. There is an amplifier that also is part of the circuit. Does anyone know how to test this componet or where can I buy one? I can't find it in any of the Nisaan parts WEB sites I visited.
davo's Avatar
07-29-04, 04:13 PM   #2
If the motor operates with a supplied power and ground the motor should be good.Do you have power and ground at hte connector for the motor with the switch applied?You may have a broken wire at the drivers door or rr door.
