'90 f150 actuator rod
EscapedMum's Avatar
07-29-04, 06:20 PM   #1
EscapedMum
How do I install a new actuator rod/lever assembly? My actuator lever broke, and I can't figure out how to manipulate the new assembly between the tilt assembly and the casting.
Thank you!
bejay's Avatar
07-30-04, 09:18 PM   #2
have you removed the 2 pins from the tilt assembly to move the tilt assembly rearward the pins have a threaded hole they do make simple pullers for, a bolt the same thread size a washer and socket would likely work just as well.
