94 Blazer idles errattic
Old 07-30-04, 03:52 AM
Angry 94 Blazer idles errattic
Have a 1994 Chevy Blazer S-10 that idles errattically. Also when I try to stop it litterally will not stop. Brakes work fine, but is dumping so much fuel that it just keeps going forward. At some time, someone disconnscted the 4 wheel drive, because the brakes kept locking up. Any ideas anyone?
Old 07-30-04, 12:28 PM
Desi501's Avatar
I would suspect that it's not fuel that's messing you up, but rather an air leak is most likely the cause. A bad vacuum would not only give you a high, erratic idle but the low vacuum supply to the brake booster could explain your brake problems. What you need to do is first thoroughly clean the throttle body and IAC motor. Then look very hard for a vacuum leak somewhere. You could start by taking a vacuum reading to see just where you stand. You should have at least 16-17in of vacuum at idle.
Old 07-30-04, 01:58 PM
I'll place my bet on a chunk of carbon stuck in the egr valve.
Old 07-31-04, 12:56 PM
you took the right bet. Now what would be be causing the carbon? I put a fuel additive in the fuel tank to clean the injectors.
Old 07-31-04, 03:48 PM
Go to an auto parts store and ask for a problem solver egr gasket it is a tomco part #.If you really need to know the part # I can find it for you.The carbon is from fuel quality and I don't mean low octane fuel.Premium fuel will cause more carbon buildup because it burns slower.You can't eliminate carbon buildup in newer engines it is because of newer emission standards causing manufacturers to run leaner air fuel ratios.Leaner burn more left over carbon atoms.
Old 07-31-04, 04:38 PM
Thanks man. It's not my rig, so you've been a big help. Lady says the SUV hasn't run this good since she bought it. Oh ,and by the way, I told her who gave me the knowlegde to fix it. Thanks again.
Steve
