Shadetree air conditioning has major problem
Old 07-31-04, 04:28 PM
shadetree
Question Shadetree air conditioning has major problem
I just need to know what the pressure should be on the high and low on my 92 Chrysler- Town/Country its a 3.3 front wheel drive , it also has front and rear air ?
Old 08-01-04, 03:42 AM
Desi501's Avatar
It's not that simple. There are many varying factors in that such as what blower speed your on, what outside temp is, what rpm your engine is at, the condenser fan is 2 speed and will change pressures drastically when high speed kicks in. Dual systems generally run higher on the low side but you should be between 33 and 43 at idle after equelizing. The high side should be between 175 and 275. The current circumstances can vary the pressure. Even being withing these ranges, proper interpretation could spot a problem.
