94 Ford Explr Xlt/ Windw Stuck Down
BOTTOMLINEROX's Avatar
08-01-04, 02:03 PM   #1
BOTTOMLINEROX
my front passenger window is stuck in the down position, and will not respond to the electric up/down button controller. could you please tell me how to fix this ? thanx, nk
jeff67's Avatar
NC
08-01-04, 07:05 PM   #2
You either have a bad window motor, a bad window switch at one of the front doors, an open wire connection, or the window is binding on the guides. If the window doesn't seem to be getting any power, check the switches 1st.
tlow's Avatar
08-03-04, 01:02 PM   #3
tlow
94 Ford Explr Xlt/ Windw Stuck Down Reply to Thread
Nine times out of ten all you need to do is take the switch apart and clean up the contacts. This is the part of the switch which completes the circuit when you push down on it Because of the design, the switch housing (faces up) lends itself to filling up with dirt, rain, spilled drinks>>>>
If you clean these up and it still won't work, try some of the other ideas that have been posted by others.
