engine cost?
Old 08-06-04, 02:49 PM
Sweet1
Question engine cost?
What does a rebuilt engine cost approximately for an Explorer 1995? V6, 2 wheel drive?
Anyone know?
Old 08-06-04, 02:55 PM
Desi501's Avatar
The engine itself is probably around $2000-2500. Installing it and changing all the hoses, water pump, ignition, radiator and all the things you should be replacing with the engine, you can easily spend $4000-5000.
Old 08-06-04, 04:48 PM
bluecanary25
Exclamation
I have a Dodge Caravan (Yeah, it has the required smoke feature )
Desi, do you have a ballpark figure to have a ring-job on 93 3.0liter Caravan?
I am thinking that should stop the smoking....... engine runs fine. Old/outdated lore was; If engine smoked, rings were worn out. Don't know if that still holds any water. Just trying to cut-back on the Camels. LOL
Old 08-06-04, 06:16 PM
Desi501's Avatar
Your talking about the same thing. You don't just replace rings.
Old 08-06-04, 06:26 PM
bluecanary25
Desi501,
Thank you for your quick reply and concise answer.
Not economical to repair/replace engine.
But I got my money's worth out of it .
Shame I never learned how to work the interior of the motor...
Now to find a lighter and a gallon of gas..... J/K!
Time to dispose of this vehicle in a responsible manner.
Again, I thank you for the fast answer.
Old 08-07-04, 03:51 AM
Desi501's Avatar
Another option would be a used motor but that would still be a considerable expense, (est. $1500) and also considerable risk.
Old 08-07-04, 04:29 AM
Sweet1
Question Explorer Engine post
Well it is economical to replace an enigine in a 1995 Explorer? I think it is time to go to Ford Heaven myself, and buy something used or brand new with better fuel efficiency and low payments under $350 a month. One year of payments would equal new engine, then the rest is my expense to drive something newer. Any thoughts?
